Upgrading from previous Connect versions
Always backup before upgrading
It is recommended that you always backup your existing Connect preferences before upgrading to a new version. This will enable you to revert back to the previous version, in a worst case scenario in which the new version introduces issues with your existing production processes. Whilst the probability of such a worst case scenario is remote, it cannot hurt to take some simple precautions, just in case.
Users of Connect prior to 2019.1
Users of Connect 1.0 should see Users of Connect 1.0 first.
Users of Connect 1.1 should see Users of Connect 1.1 first.
Users of all
If you do not have Update Client version 1.2.40 installed already, then the next time you run your Update Client it will show that there is an update available of itself to Version 1.2.40 (or later).
Simply click on the “Install” icon
to initiate the upgrade.
For further details on how to upgrade the Update Client and update your Connect License see the Update Client 1.2.40 Upgrade Guide (http://help.objectiflune.com/en/archive/Update_Client_1.2.40-Upgrade_Guide.pdf).
Note that an erroneous or incomplete uninstall before a reinstall or upgrade to a newer version of OL Connect may cause issues (see Product or engine exits within a second of starting in Connect's Knowledge Base).
In order for users of PlanetPress Connect 1.1 to upgrade to any later version through the Update Manager it is necessary to install a later version (1.1.8 or later) of the Objectif Lune Update Client.
If you do not have such a version installed already, the next time you run your Update Client it will show that there is an update available of itself to Version 1.1.8 (or later).
Simply click on the download button in the dialog to install the new version of the Update Client. Note that it is no problem to run the update while the Client is open. It will automatically update itself.
Once you have done this, PlanetPress Connect2020.2 will become available for download.
Users of Connect version 1.0 cannot upgrade directly to Version 2020.2. This is because Connect Version 1.0 is a 32 bit version of Connect.
Users must first upgrade to Version 1.1 and from there upgrade to Version 2020.2
If you are updating manually you must first upgrade to Version 1.1 before installing 2020.2. If you attempt to go directly from Version 1.0 to Version 2020.2 the installation will fail.
Also see Users of Connect 1.1 for extra information about updating from that version.
