Send to Server dialog
The Send to Server dialog sends selected templates, data mapping configurations and Print Presets to the PlanetPress Connect Server or to another server of your choice.
Configurations: Initially this list contains the Connect template and data mapping configuration that are currently open, and the Job Creation Preset and Output Creation Preset that were last modified.
- Browse: This button opens the Select Files dialog that lets you add one or more templates, data mapping configurations, Print Presets, and/or package files to the list. When you select a package file, its contents will be sent to Workflow; the package file itself is not sent.
- Select Preset: Opens the Select Preset dialog. This dialog lists all Print Presets found in the folder:
C:\Users\[UserName]\Connect\workspace\configurations. Where[username]is replaced by the appropriate Windows user name.There are two ways to make it easier to find the file that you need:
- The Show drop-down list lets you select the type of preset that you want to open.
- In the Filter field, you can enter (part of) a preset name to filter the list for matching presets.
Actually, the path may not begin with 'C:\Users', as this is language-dependent. On a French system, for example, it would be 'C:\Utilisateurs'.Select one or more Print Presets to add them to the list of configurations in the Send to Workflow dialog.
Type%userprofile%in a Windows File Explorer and press Enter to open the actual current user's home directory. - Delete: Deletes the selected file from the list of files to send.
- Server: Use the drop-down to select where to send the files. This lists the Connect Servers and any other servers configured in the preferences; see Connect Servers preferences and Web Applications preferences.
- Send: Sends all selected Connect files to the selected Connect Server. You can use the topmost checkbox to select all of the listed files at once.
- Cancel: Click this button to close the dialog without sending any files.
