Using an ESP with PlanetPress Connect
This topic explains why and how to use an ESP with PlanetPress Connect
Reasons to use an ESP
- ESPs ensure a high deliverability, as most ESPs are whitelisted or approved by ISPs (Internet Service Providers) as legitimate email delivery service. So they help you to avoid having mail detected as spam.
- ESPs provide comprehensive tracking options to measure open rates and they log which links were clicked and by who. Typically this information is available via an online dashboard.
- Most ESPs provide Bounce Management options. They will stop sending messages to addresses that return a hard bounce and retry for soft bounces before removing that address.
- EPSs can handle unsubscribes and prevent accidental sends in the future.
Choosing an ESP
The first thing to do to use an ESP with PlanetPress Connect is to choose an ESP and create an account.
PlanetPress Connect has been tested with: Mandrillap.com, SendGrid (easy user management), MailGun (nearly instant statistics) and MailJet (shows best performance on the free account).
After creating an account, add a SMTP settings preset in PlanetPress Connect for the chosen ESP, via the Preferences dialog of the Designer (see Email SMTP settings).
Presets for different ESPs are already available in the list of default presets.
Sending an email with an ESP
- In the Outgoing mail settings area, select the preset for your ESP in the Presets drop-down.
- In the Password box, type the password provided by the ESP.
The ESP might also have a test function you can use. Check the options of your ESP.
For a detailed description of how to use Mandrill to send and track emails, see the following how-to: Using Mandrill.
In a Connect template, these custom headers can be added via the Email section properties (see Meta information).
Alternatively custom headers may be added through a Control Script (see Control Scripts, Control Script API and section).
SendGrid
Documentation: https://sendgrid.com/docs/API_Reference/SMTP_API/using_the_smtp_api.html. (Use the SMTP API; the Connect Server sends SMTP email).
Add a name meta tag with the value X-SMTPAPI and set its content to the required JSON string (for example: "' category': ['invoices']").
You can make this setting in the Email section properties (see Meta information).
Alternatively you could write a Control Script, for example:
var headerObj = {
"category": ["invoices"]
Sendgrid strips out their mail headers. The results need to be verified via their Dashboards (e.g. the Stats section lets you verify the stats for specific categories). Alternatively one can use their Web API to retrieve stats in JSON format. To view the category stats, log in to Sendgrid and choose: Stats > Category Stats > your category name.![]()
MailGun
Add a name meta tag with the value X-Mailgun-Tag and set its content (for example: invoices).
var headerObj = {
"category": [
"dogs",
"animals",
"pets",
"mammals"
section.addHeader("X-SMTPAPI", JSON.stringify(headerObj));
The Mailgun tag allows you to view the stats per tag. Mailgun has a quick refresh and stats are available almost instantly.![]()
MailJet
Dashboard: https://app.mailjet.com/dashboard
To assign a campaign, set a meta tag of the type name with the value X-Mailjet-Campaign and set its content to the name of the campaign (for example: invoices).
Mailjet strips out their own mailheaders like X-Mailjet-Campaign. The results can only be verified via the respective campaign stats page in the Mailjet dashboard. There is no need to pre-create the campaign: adding it to the email header via a Control Script auto-generates the campaign. To view the campaign, login to Mailjet and choose: Campaigns > All.![]()
