7.67.52015-05-06
Exit PlanetPress Design
Once you are done working on your PlanetPress Design document, you can close the program. You may exit the PlanetPress Design in any of the following ways:
  1. From the PlanetPress Design Button, choose Exit.
  2. Click the X at the top-right corner of PlanetPress Design.
  3. Press ALT+F4 on your keyboard.
  4. Right-click on the PlanetPress Design button in your task bar, and select Close.
If your document has been changed, a dialog appears asking you if you want to save the file. Choose one of the following options:
