7.67.52015-05-06
Object Preview Window
The Object Preview window lets you see objects before they are actually created. The object preview window has its own Message area displaying PlanetPress Talk error messages.
You use it to preview the effect of property settings, and to help determine the appropriate setting for a given property. As you change the property settings of an object or a group, the Object Preview updates to display the result of the modifications. It can also display messages from the PlanetPress Talk Converter that can help you debug the object or group.
To show or hide the Object Preview:
The following options are available in the Object Preview window toolbar:
You can reposition the contents of the Object Preview by clicking and dragging the preview around, or by using the scrollbars.
