7.67.52015-05-06
Color Preferences
To set PlanetPress Talk Editor Color options:
  1. From the PlanetPress Design Button, choose Preferences.
  2. If necessary, expand PressTalk Editor, and click Color.
    Element list: Displays the list of code elements. Use to select the element whose color and/or style attributes you want to adjust. Select None to set the color for all elements that do not appear in the list. To set a color and style attribute for an element, select that element in the Element list, then use the Mapping, Background, and Foreground lists, and the Attributes check boxes to set the color and style attributes for that element. Repeat for each element whose color and style you want to adjust.
    Mapping: Use to select a color palette. The color palette determines the colors available in the Foreground and Background color lists.
    Foreground: Use to select the foreground color for the selected element.
    Background: Use to select the background color for the selected element.
    Attributes: Use to set the style attributes for the selected element. You can select any combination of bold, italic, and underlined.
    PlanetPress Talk label color: Select the label color for boxes that accept PlanetPress Talk code. The label color you select for these boxes serves to distinguish them from those which do not accept PlanetPress Talk code.
    PlanetPress Talk background color: Select the background color for boxes that accept PlanetPress Talk code. The background color you select for these boxes serves to distinguish them from those which do not accept PlanetPress Talk code.
  3. Click OK.
