7.67.52015-05-06
Associate Attachments with a Page
When you associate an attachment with a page, you define whether you want that attachment to execute before or after the page executes. You can associate a condition with each attachment that determines whether the attachment executes.
To associate attachments with a page using drag and drop:
To associate attachments with a page using the Page properties dialog box:
  1. In the Structure area, select the attachment resources you want to associate with the page, and, staying in the Structure area, drag and drop them onto the page with which you want to associate them.
  2. In the Page properties dialog box, click Attachments.
  3. Add the attachments you want to execute before and/or after the page.
    Attachments run before page: Display, define, and/or edit the list of attachments you want to execute before the page executes. The attachments execute sequentially, from top to bottom. Right-click in this area and use the menu that appears to add or delete items, move items up or down in the list, or clear the list altogether. You can also delete an item by selecting it and pressing DELETE.
    Attachments run after page: Display, define, and/or edit the list of attachments you want to execute after the page executes.
  4. Click OK.
