7.67.52015-05-06
Adjust Alignment and Lines Per Unit settings
To adjust the text justification:
  1. Verify that word wrap is on. The justification tools are available only when word wrap is on.
  2. Do any of the following to define the region of text to which you want to apply a new text justification setting:
    • To change the justification for a single paragraph, click anywhere in that paragraph.
    • To change the justification for one or more contiguous paragraphs, click and drag to highlight those paragraphs.
    • To change the justification for text you enter from this point forward, click at the new paragraph position.
  3. Locate the Text Justification toolbar.
  4. Click the appropriate justification tool.
    Left justify the text.
    Right justify the text.
    Center justify the text.
    Left and right justify the text.
To adjust the lines per unit:
  1. Do any of the following to define the region of text to which you want to apply a new lines per unit (LPU) setting:
    • To change the LPU for a single paragraph, click anywhere in that paragraph.
    • To change the LPU for one or more contiguous paragraphs, click and drag to highlight those paragraphs.
    • To change the LPU for text you enter from this point forward, click at the new paragraph position.
  2. Locate the Lines per unit box in the toolbar.
  3. Do any of the following:
    • Select an LPU value from the drop-down list.
    • Enter a new integer value in the Lines per unit box.
    • Select Automatic to have PlanetPress Design automatically adjust the LPU to accommodate the largest font size in the paragraph. If you subsequently modify the font size of any of the styles the paragraph uses, PlanetPress Design automatically adjusts the LPU to reflect the modification. Automatic is the default value for the LPU setting.
