7.67.52015-05-06
Add PostScript Attachment Resources
To add PostScript attachment resources:
  1. Do the following to select the attachment or attachments you want to add to the document:
    Single POSTSCRIPT attachment resource
    • Choose Home | Document | Attachment, and in the Open dialog box that appears, navigate to the attachment file you want to add and select it.
      Single or multiple POSTSCRIPT attachment resources
    • Locate the attachment files on the desktop. Click on the first file you want to add, and then CTRL+click to add individual files to the selection. CTRL+click a file a second time to remove it from the selection.
  2. Press CTRL+C to copy the files, then click the Attachments folder in the Structure area and press CTRL+V to paste the files.
    If you add an attachment with the same name as an attachment that currently exists in the document, PlanetPress Design appends a number to the name of the new attachment.
    If you selected Invalid added resources messages in the User Options dialog box, PlanetPress Design reports any failure to add some or all the files.
  3. If necessary, rename the Postscript attachment resources.
