7.67.52015-05-06
Supported Barcodes
This section provides basic information on the barcodes supported by PlanetPress Design, such as which characters are compatible with which barcodes, how many characters can be used in a given barcode, etc.
Australia Post
This barcode must begin with one of the following two digit Format Control Code (FCC) number:
11, 59, or 62.
The FCC number must be followed by eight (8) digits. These are mandatory to specify the destination. Additional characters may be used for the Customer Information Field. The number characters varies according to each FCC format:
Compatible characters for the Customer Information Field include:
A checksum is automatically calculated.
Aztec
This barcode can be used to generate Normal, Compact or Full Aztec barcodes. This barcode supports the full ASCII character set and its maximum data capacity depends on the selected barcode type:
Bar width is set using millimeters and corresponds to the minimum barcode width.
Error correction levels correspond to the percentage the symbol that includes error checking data. Note that level 0 provides optimal error correction. Each barcode mode has its own value range (Normal mode values range from 0 to 99, Compact from 0 to 4; and Full from 0 to 32).
CEPNet (Brazilian Postal Code)
CEPNet is the equivalent of the PostNet barcode but is used in Brazil. It uses the same basic specifications as PostNet and thus looks graphically similar.
CEPNet accepts an 8-digit Brazilian postal code and will fail on any other data.
Codabar
This barcode must start with a Start character and end with a Stop character. Characters A, B, C and D can be used as Start and Stop characters.
For the remaining barcode data, the following characters may be used:
CodablockF
This 2D barcode can currently only be used in documents that will be printed using either the Optimized Postscript or Windows Printing mode (printer centric mode will be added in a future release).
This barcode supports the full ASCII character set based on the 3 alphabets used in the Code128 barcode (see below). The switch between alphabets is done automatically. Special characters in the A alphabet are called with their ASCII value using the following syntax: ^nnn (such as ^010 for LineFeed).
A minimum of 3 characters is required in this barcode. The maximum string length for this barcode varies depending on the control characters used in the code. Bar width is set using millimeters and corresponds to the minimum barcode width.
Code 11
The following characters are valid for this barcode:
A checksum is optional, but should be added to ensure data reliability. When the Checksum option is selected, the required checksum digits are added automatically.
Code 16k
This barcode supports the full ASCII character set based on the 3 alphabets used in the Code128 barcode (see below). A maximum of 5 characters per row over 16 rows is permitted. If the first 4 characters in the data are numeric, a 'SwitchC' character is automatically added before the data. Special characters within the data can be used to switch alphabets in the same way as with the Code 128 barcode.
The selected barcode mode determines the starting codeset and leading character:
Code 39
To go beyond the 44 basic characters listed above, you may use extended ASCII characters (granted that scanners are programmed for this, otherwise extended characters will simply be read as basic characters).
To use extended characters, use the encoding listed in the following table:
Character
Encode as
Character
Encode as
Character
Encode as
Character
Encode as
NUL
%U
SP
Space
%V
%W
SOH
$A
/A
A
A
a
+A
STX
$B
/B
B
B
b
+B
ETX
$C
/C
C
C
c
+C
EOT
$D
/D
D
D
d
+D
ENQ
$E
/E
E
E
e
+E
ACK
$F
/F
F
F
f
+F
BEL
$G
/G
G
G
g
+G
BS
$H
/H
H
H
H
+H
HT
$I
/I
I
I
i
+I
LF
$J
J
J
j
+J
VT
$K
/K
K
K
k
+K
FF
$L
/L
L
L
l
+L
CR
$M
M
M
m
+M
SO
$N
N
N
n
+N
SI
$O
/O
O
O
o
+O
DLE
$P
0
0
P
P
p
+P
DC1
$Q
1
1
Q
Q
q
+Q
DC2
$R
2
2
R
R
r
+R
DC3
$S
3
3
S
S
s
+S
DC4
$T
4
4
T
T
t
+T
NAK
$U
5
5
U
U
u
+U
SYN
$V
6
6
V
V
v
+V
ETB
$W
7
7
W
W
w
+W
CAN
$X
8
8
X
X
x
+X
EM
$Y
9
9
Y
Y
y
+Y
SUB
$Z
/Z
Z
Z
z
+Z
ESC
%A
%F
%K
%P
FS
%B
%G
%L
%Q
GS
%C
%H
%M
%R
RS
%D
%I
%N
%S
YS
%E
%J
_
%O
DEL
%T,%X,%Y,%Z
Code 49
The data for this barcode can include both numeric and alphanumeric characters. When only numbers are present in the data, the maximum number of characters is 82. When alphanumeric characters are present, the maximum is 50 characters.
Code 93
To use extended characters, use the encodings listed in the following table:
Character
Encode as
Character
Encode as
Character
Encode as
Character
Encode as
NUL
(%)U
SP
Space
(%)V
(%)W
SOH
($)A
(/)A
A
A
a
(+)A
STX
($)B
(/)B
B
B
b
(+)B
ETX
($)C
(/)C
C
C
c
(+)C
EOT
($)D
(/)D
D
D
d
(+)D
ENQ
($)E
(/)E
E
E
e
(+)E
ACK
($)F
(/)F
F
F
f
(+)F
BEL
($)G
(/)G
G
G
g
(+)G
BS
($)H
(/)H
H
H
H
(+)H
HT
($)I
(/)I
I
I
i
(+)I
LF
($)J
(/)J
J
J
j
(+)J
VT
($)K
(/)K
K
K
k
(+)K
FF
($)L
(/)L
L
L
l
(+)L
CR
($)M
M
M
m
(+)M
SO
($)N
N
N
n
(+)N
SI
($)O
(/)O
O
O
o
(+)O
DLE
($)P
0
0
P
P
p
(+)P
DC1
($)Q
1
1
Q
Q
q
(+)Q
DC2
($)R
2
2
R
R
r
(+)R
DC3
($)S
3
3
S
S
s
(+)S
DC4
($)T
4
4
T
T
t
(+)T
NAK
($)U
5
5
U
U
u
(+)U
SYN
($)V
6
6
V
V
v
(+)V
ETB
($)W
7
7
W
W
w
(+)W
CAN
($)X
8
8
X
X
x
(+)X
EM
($)Y
9
9
Y
Y
y
(+)Y
SUB
($)Z
(/)Z
Z
Z
z
(+)Z
ESC
(%)A
(%)F
(%)K
(%)P
FS
(%)B
(%)G
(%)L
(%)Q
GS
(%)C
(%)H
(%)M
(%)R
RS
(%)D
(%)I
(%)N
(%)S
YS
(%)E
(%)J
_
(%)O
DEL
(%)T, (%)X, (%)Y, (%)Z
A checksum is mandatory for this barcode (it is always added automatically).
Code 128
Code 128 uses 3 alphabets, each containing 106 characters:
In the case of alphabet A, to enter the non-printable characters listed as ordinals 64 to 94 in the following table, you must use alphabet B equivalents (for the ACK character, for example, use character f).
The non-printable characters listed as ordinals 95 to 105 can be entered using their ordinal value preceded by ^. To enter FNC1, for example, you would enter ^102. To enter an actual ^ character, you would enter ^062.
Numeric values entered using alphabet C are always considered as digit pairs (0001, for example, for values 0 and 1). Only when you use alphabets A or B can you enter an odd number of digits (001, for example, for values 0, 0 and 1).
Having {} taken as a pair of characters to be converted into alphabet C will fail the job and result in a typecheck error.
The following table lists the characters that can be used in all three alphabets:
Ordinal
Value in alphabet
Encoding
Ordinal
Value in alphabet
Encoding
A
B
C
A
B
C
00
SP
SP
00
11011001100
53
U
U
53
11011101110
01
01
11001101100
54
V
V
54
11101011000
02
02
11001100110
55
W
W
55
11101000110
03
03
10010011000
56
X
X
56
11100010110
04
04
10010001100
57
Y
Y
57
11101101000
05
05
10001001100
58
Z
Z
58
11101100010
06
06
10011001000
59
59
11100011010
07
07
10011000100
60
60
11101111010
08
08
10001100100
61
61
11001000010
09
09
11001001000
62
62
11110001010
10
10
11001000100
63
_
_
63
10100110000
11
11
11000100100
64
NUL
64
10100001100
12
12
10110011100
65
SOH
a
65
10010110000
13
13
10011011100
66
STX
b
66
10010000110
14
14
10011001110
67
ETX
c
67
10000101100
15
15
10111001100
68
EOT
d
68
10000100110
16
0
0
16
10011101100
69
ENQ
e
69
10110010000
17
1
1
17
10011100110
70
ACK
f
70
10110000100
18
2
2
18
11001110010
71
BEL
g
71
10011010000
19
3
3
19
11001011100
72
BS
h
72
10011000010
20
4
4
20
11001001110
73
HT
I
73
10000110100
21
5
5
21
11011100100
74
LF
j
74
10000110010
22
6
6
22
11001110100
75
VT
k
75
11000010010
23
7
7
23
11101101110
76
FF
l
76
11001010000
24
8
8
24
11101001100
77
CR
m
77
11110111010
25
9
9
25
11100101100
78
SO
n
78
11000010100
26
26
11100100110
79
SI
o
79
10001111010
27
27
11101100100
80
DLE
p
80
10100111100
28
28
11100110100
81
DC1
q
81
10010111100
29
29
11100110010
82
DC2
r
82
10010011110
30
30
11011011000
83
DC3
s
83
10111100100
31
31
11011000110
84
DC4
t
84
10011110100
32
32
11000110110
85
NAK
u
85
10011110010
33
A
A
33
10100011000
86
SYN
v
86
11110100100
34
B
B
34
10001011000
87
ETB
w
87
11110010100
35
C
C
35
10001000110
88
CAN
x
88
11110010010
36
D
D
36
10110001000
89
EM
y
89
11011011110
37
E
E
37
10001101000
90
SUB
z
90
11011110110
38
F
F
38
10001100010
91
ESC
91
11110110110
39
G
G
39
11010001000
92
FS
92
10101111000
40
H
H
40
11000101000
93
GS
93
10100011110
41
I
I
41
11000100010
94
RS
94
10001011110
42
J
J
42
10110111000
95
US
DEL
95
10111101000
43
K
K
43
10110001110
96
FNC3
FNC3
96
10111100010
44
L
L
44
10001101110
97
FNC2
FNC2
97
11110101000
45
M
M
45
10111011000
98
SHIFT
SHIFT
98
11110100010
46
N
N
46
10111000110
99
Code C
Code C
99
10111011110
47
O
O
47
10001110110
100
Code B
FNC4
Code B
10111101110
48
P
P
48
11101110110
101
FNC4
Code A
Code A
11101011110
49
Q
Q
49
11010001110
102
FNC1
FNC1
FNC1
11110101110
50
R
R
50
11000101110
103
START A
START A
START A
11010000100
51
S
S
51
11011101000
104
START B
START B
START B
11010010000
52
T
T
52
11011100010
105
START C
START C
START C
11010011100
STOP
STOP
STOP
11000111010
The checksum is always calculated automatically.
Datamatrix
This barcode supports the full ASCII character set and its maximum data capacity depends on the data type and the selected barcode mode:
Error correction levels depends on the selected barcode mode. Levels range from 0 to 6 in Rectangular mode, and from 0 to 24 in Square mode.  Note that the number of characters available is inversily proportional to the error correction that has been set.
Discrete 2 of 5
A checksum is automatically calculated. Optional bearer bars can be added for added reliability.
FIM
This static code can only represent one of three available FIM types: FIMA, FIMB, and FIMC.
GS1 Databar (RSS)
This barcode supports digits only and the maximum number of characters allowed is based on the selected barcode mode.
IMB/OneCode
The Intelligent Mail Barcode is used by USPS to track letters and flats. The barcode has no selectable option, but the data must be formatted in a very specific way to be useable. The data must be one single string of digits, composed of the following items:
For more information on the OneCode barcode, please see http://ribbs.usps.gov/onecodesolution.
Japan Post
The Japan Post barcode will accept digits and uppercase letters and the hyphen. The data consists of a 7 digit postal code plus address data. If the address data is less than 13 characters the remaining character positions are filled with control characters to make the length 20.
The postal code section may have a hyphen at the 4th character position (eg. 123-4567) although this hyphen does not appear in the encoded data. There may also be a hyphen between the postal code and the address data (eg. 154-0023-1-3-2-A-507). Again this hyphen does not appear in the encoded data. Note that the remaining hyphens are encoded.
Maxicode
This 2D barcode can be used in documents that will be printed using the Optimized Postscript, Windows Printing or printer centric mode.
This barcode supports various data types and the maximum number of characters allowed is based on the selected barcode mode:
Note that the Barcode Options page of the Barcode dialog box may also be used to enter the data. When
mode 2 or 3 is selected, all the corresponding dialog box fields are accessible. When mode 4, 5 or 6 is
selected, only the Message dialog box field may be used to enter data. Entering data this way supersedes
any data entered using the Data page of the Barcode dialog box.
Micro PDF417
The number of columns in the barcode may be selected as required up to a maximum limit of 4 columns.
Note that the error correction level is always set automatically.
Micro QR
Error correction may be set from Level 0 to Level 3.
MSI Plessey
This code can contain a variable number of characters. The following characters are valid for this barcode:
A checksum is added automatically.
PDF417
This 2D barcode replaces the PDF417 barcode used in previous versions of PlanetPress Design. It can be used in documents that will be printed using the Optimized Postscript, Windows Printing or printer centric mode.
If you open document that uses the “old PDF417 barcode”, existing PDF417 barcodes will remain unchanged, and any new PDF417 barcode that you may add to that document will also use the “old PDF417 barcode”. If you want this older document to use the new barcode, you will have to delete all its “old PDF417 barcodes”, to save the document, and then to add new PDF417 barcodes. Barcodes added to older documents that did not contain any PDF417 barcode or to new documents will be added using the “new PDF417 barcode”.
The number of columns in the barcode may be selected as required up to a maximum limit of 20 columns.
Error correction may be set from Level 0 to Level 8.
Place a checkmark in the Truncated box to make the barcode a truncated PDF417 barcode. By default, barcodes are added as standard PDF417 barcodes.
Plessey
A two-digit checksum is added automatically.
USPS Postnet
Standard Postnet codes must contain exactly 5 characters. The following characters are valid for this barcode:
Apart from the standard Postnet code, two additional codes can also be used:
QR Code
Royal Mail
UPC
The UPC barcode in PlanetPress Design supports multiple subtypes:
UPC-A
Standard UPC-A codes must contain exactly 12 characters (including the checksum character). The following characters are valid for this barcode:
Apart from the standard UPC-A code, two additional codes can also be used:
UPC-E
Standard UPC-E codes must contain exactly 8 characters:
Apart from the standard UPC-E code, two additional codes can also be used:
EAN-13
The standard code must contain exactly 13 characters (this includes one checksum character).
Apart from the standard EAN-13 code, two additional codes can also be used:
A checksum is automatically calculated for this barcode.
Human readable characters are always included in the code.
EAN-8
The standard EAN-8 code must contain exactly 8 characters (this includes one checksum character).
Apart from the standard EAN-8 code, two additional codes can also be used:
ISBN
Standard ISBN barcodes contain 10 digits (9 digits for the data plus 1 checksum digit) or 13 digits (a 3 digit prefix, 9 digits for the data plus 1 checksum digit).
Using hyphens or spaces is not compulsory but recommended to clearly separate each part of the code.
Apart from the standard ISBN code, two additional codes can also be used:
