7.67.52015-05-06
Lock and Unlock Objects and Groups
To lock an individual object/group:
To unlock an individual object/group:
To lock one or more objects/groups in a single operation:
  1. If necessary, in the Structure area, select the page containing the object(s) and/or group(s) whose Selectable property you want to clear.
  2. Do either of the following:
    • To lock only a selected set of objects/groups: Verify that all the objects you want to lock are selected, then choose Page Layout | Lock/Unlock | Lock Selected Objects.
    • To lock all objects/groups: Choose Page Layout | Lock/Unlock | Lock All Objects on Page.
To unlock one or more objects/groups in a single operation:
  1. If necessary, in the Structure area, select the page containing the object(s) and/or group(s) you want to unlock.
    • To unlock only a selected set of objects/groups: In the Structure area, select each object you want to unlock, then choose Page Layout | Lock/Unlock | Unlock Selected Objects.
    • To unlock all objects/groups: Choose Page Layout | Lock/Unlock | Unlock All Objects on Page.
