Use: |
To: |
CTRL+Z or ALT+BACKSPACE |
Undo the last command or group of editing commands entered, depending on the setting of the Group undo check box in the User Options dialog box. If you selected Group undo, the Editor undoes the last group of editing commands entered. If you cleared Group undo, the Editor undoes only the last editing command entered. Repeat to continue undoing each preceding editing command or group of editing commands. |
