7.67.52015-05-06
Using Foreign Language Text with PPtalk
Can PlanetPress Talk let me use foreign language text in PlanetPress?
You can use Text objects to display both static text and variable content, such as data selections, in the same object. Text objects also let you mix foreign language text, such as Arabic, and European language styles within the same object, although not in the same paragraph.
