7.67.52015-05-06
Store two lines of input data on one line of the data page
This sample is a user-defined emulation that reads two lines of input data, concatenates them, and stores them as a single line in the data page buffer. It terminates a data page when it encounters a form feed character. The emulation relies on two global variables:
Variable:
Type:
Initialized to:
Description:
&second
Boolean
False
The emulation uses this to determine when the current line is a second line of data. It is True when the current line is a second line of data.
&line
string
““ (the empty string)
Holds the contents of a first line of data.
Code:
% STORE TWO LINES OF DATA ON ONE LINE OF THE DATA PAGE
search(&str,'\014')
 set(&current.line,&current.line + 1)
 store(&current.line,&str)
 doform()
 set(&second,false)
 clearpage()
endsearch()
if(&second)
 store(&current.line,&line + &str)
elseif()
 set(&line,&str)
endif()
set(&second,not(&second))
if(ge(&current.line,&current.lpp))
 doform()
 clearpage()
 set(&second,false)
endif()
Notes:
