7.67.52015-05-06
Add (function)
Adds two numerical expressions. This is the functional equivalent to the + operator, when you use the + operator with numerical expressions.
Syntax
add( expression, expression2 ) integer, measure, currency value
Arguments
expression1, expression2
Integer, measure, or currency values. Both expressions must be the same type. The returned value is set according to the type of the parameters.
Code Sample Examples
Examples 1 and 2 show both ways of adding numbers.
Example 1
show(inttostr(2+2)) %Displays 4
Example 2
show(floattostr(add(4.7,2.1))) %Displays 6.8
