7.67.52015-05-06
Breakpoint (procedure)
Stops the execution of a PlanetPress Talk object when the specified expression is True. This breakpoint is effective only when running in debug mode in the PlanetPress Talk editor.
Syntax
breakpoint( expression1 )
Argument
expression1
Boolean value.
Code Sample Example
This example sets up a loop, stops the loop on its 5th iteration, and then displays the value.
Example
define(&x,integer,1)for(&x,1,1,10)
	breakpoint(&x = 5)
	show(inttostr(&x))
endfor()
