7.67.52015-05-06
LE (function)
Compares two expressions of any type and returns true if the first is less than or equal to the second, false otherwise. This is the functional equivalent to the <= operator.
Syntax
le( expression1, expression2 ) Boolean value
Arguments
Values of any type. Both expressions must be of the same type.
Code Sample Example
This example shows both ways of comparing two expressions.
Example
if(le(&current.line, 15) )
  show('Top of page')
endif()
%Same statement, using the <= operator
if(&current.line <= 50)
  show('Top of page')
endif()
