Negates the specified expression. Not to be confused with the neg function: not is a Boolean operator function, not a mathematical one.
not( expression1 )
 Boolean value
expression1
Boolean value.
This example shows how NOT can be used in place of operators.
define(&x,integer,1) %Define loop variable
for(&x,1,1,10) %Set loop
if(not(&x=5)) %Same as if(&x<>5)
    show('This is NOT the 5th line') %Show some textelseif()
    show('This IS the 5th line') %Show alternateendif()
endfor()
