7.67.52015-05-06
Put (procedure)
Assigns a value to an element of an array.
Syntax
put( &array, index, value )
Arguments
&array
Array variable containing the element whose value you want to change.
index
Integer value representing the position of the element in the array.
value
The value you want to assign to the element. The value must be of the same the type as the array. Thus if the array is of type string, the value must be of type string.
