7.67.52015-05-06
ShowUTF8Left / ShowUTF8Right / ShowUTF8Center (procedure)
These three commands are used to display simple text strings on the document. They are identical in all aspects, except in the way they behave relative to the text insertion point: showUTF8Left displays the text from the insertion point to the left; showUTF8Right displays the text from the insertion point to the right; and showUTF8Center displays the text equally on both sides of the insertion point.
These commands cannot be used with a beginUTF8paragraph...endUTF8paragraph structure.
Syntax
showUTF8left( text, mode)
showUTF8right( text, mode )
showUTF8center( text, mode )
Argument
text
Static text string or data selection to be displayed. Bear in mind that the information, wether static or variable, must be in UTF8. The maputf8 function can be used to convert the information to UTF8.
mode
String value specifying the contextual analysis is to be performed. Possible values are 'normal', 'reverse', and 'none' (for no contextual analysis).
Code Sample Examples
Example 1
This example illustrates a static text string (the name Saudi Arabia) escaped to its UTF8 reference form that will be displayed from the insertion point to the left.
setlinewidth(0.007)
moveto(0,0)
rlineto(&width,0)
rlineto(0,&height)
rlineto(neg(&width),0)
rlineto(0,neg(&height))
closepath()
stroke()
moveto(&width/2,&height/2)
SetStyleExt(&Style1,12.0000,0,[100],100)
showUTF8left('\u0627\u0644\u0633\u0639\u0648\u062F\u064A\u0629',	'normal')
Example 2
This example shows a variable text string that is taken from the data, converted from the MS-CP-1256 encoding to UTF8 and then displayed from the insertion point to the right.
setlinewidth(0.007)
moveto(0,0)
rlineto(&width,0)
rlineto(0,&height)
closepath()
stroke()
showUTF8right(maputf8(@(2,15,35), 'MS-CP-1256', False),'normal')
