8.18/6/2018
Object Duplication Preferences
To set the Object Duplication options:
  1. From the PlanetPress Design Button, choose Preferences.
  2. If necessary, expand Behavior, and click Object duplication.
  3. Adjust the Object Duplication options.
    Duplicate style: Select where you want PlanetPress Design to place the copy of any object, group, or selection of objects and/or groups you duplicate. Select Pack vertically to have PlanetPress Design align the copy along the Y axis, under and flush with the most recent copy. Select Pack horizontally to have PlanetPress Design align the copy along the X axis, to the right of and flush with the most recent copy. Select Relative displacement to have PlanetPress Design align the copy using the specified horizontal and vertical offset values. If you select this option, you must enter values for the vertical and horizontal displacements.
    The menu items Edit | Duplicate and Pack Horizontally and Edit | Duplicate and Pack Vertically,override this setting.
    Vertical relative displacement value: Enter the displacement for the copy along the Y axis. Units are as set in the User Options dialog. This option is available only when you select Relative displacement as the duplicate style.
    Horizontal relative displacement value: Enter the displacement for the copy along the X axis. Units are as set in the User Options dialog. This option is available only when you select Relative displacement as the duplicate style.
    Data SELECTION Offsets
    Row/child record: Set the number of lines you want to advance in the data page with each duplication of an object or group. In the case of a database emulation, this is the number of records you want to advance in the record set with each duplication of an object or group. This permits each copy to display a distinct selection of data. Note that this offset does not work with objects that use custom data selections.
    Column: Set the number of columns you want to advance in the data page with each duplication of an object or group. This permits each copy to display a distinct selection of data. Note that this offset does not work with objects that use custom data selections. This offset has no effect in database emulation.
  4. Click OK.
