8.18/6/2018
Compiler Messages Preferences
To set Converter Messages options:
  1. From the PlanetPress Design Button, choose Preferences.
  2. If necessary, expand Appearance, and click Compiler messages.
  3. Adjust the color you want to use for each type of message.
    Compile error: Select the color for any compilation error messages that appear in the Messages area of the Program window or of the Object Preview.
    Run error: Select the color for any run error messages that appear in the Messages area of the Program window or of the Object Preview.
    Warning: Select the color for any warning messages that appear in the Messages area of the Program window or of the Object Preview.
    Output Debug String: Select the color for any output debug string messages that appear in the Messages area of the Program window or of the Object Preview. Consult the PlanetPress Talk Language Reference for help with the outputdebugstring() command that produces these messages.
  4. Set the behavior of the Messages area when a new message arrives.
    Show Messages area on new message: Select to have PlanetPress Design make the Messages area, if it is currently hidden, visible when a new message arrives. Note that if you select this option, and the undocked Messages area appears over the page in the Page area, you cannot close the Messages area if any of the objects or groups on the page issues a converter message when it executes. Each time you attempt to close it, PlanetPress Design redraws the page, executing each of the objects or groups on the page; the compiler messages that result from the execution cause the Messages area to become visible again. In this case you must move the Messages area outside the page to close it.
  5. Click OK.
