8.18/6/2018
N-Up Object
The N-Up Object is used to execute a virtual page N-Up. N-Up refers to executing a page such that two or more instances of it print on one side of a sheet of paper.The page you execute N-Up must be of type virtual, however it overlays can be associated with the virtual page. When PlanetPress Design scales the virtual page in the N-Up object, it simultaneously scales any overlays associated with that page.
Data Pages and N-Up: It is important to note that because the N-Up object can change the data page within a single page, any other object after the N-Up object that uses data selection will always point to the last data page.
In addition to the common object properties, N-Up objects have the following properties:
