8.18/6/2018
Adjust the Scanline Orientation of Images
  1. Double-click on the Document node.
  2. In the Document properties dialog box, click Resource options and in the Images scanline orientation box, select the appropriate setting for the image resources you add to the document.
    Images scanline orientation: Select the default scanline orientation for all bitmapped image resources in the document.
  3. Click OK.
To adjust the scanline orientation for an individual image resource in the document:
