This section provides basic information on the barcodes supported by PlanetPress Design, such as which characters are compatible with which barcodes, how many characters can be used in a given barcode, etc.
This barcode must begin with one of the following two digit Format Control Code (FCC) number:
11, 59, or 62.
The FCC number must be followed by eight (8) digits. These are mandatory to specify the destination. Additional characters may be used for the Customer Information Field. The number characters varies according to each FCC format:
Compatible characters for the Customer Information Field include:
A checksum is automatically calculated.
This barcode can be used to generate Normal, Compact or Full Aztec barcodes. This barcode supports the full ASCII character set and its maximum data capacity depends on the selected barcode type:
Bar width is set using millimeters and corresponds to the minimum barcode width.
Error correction levels correspond to the percentage the symbol that includes error checking data. Note that level 0 provides optimal error correction. Each barcode mode has its own value range (Normal mode values range from 0 to 99, Compact from 0 to 4; and Full from 0 to 32).
CEPNet is the equivalent of the PostNet barcode but is used in Brazil. It uses the same basic specifications as PostNet and thus looks graphically similar.
CEPNet accepts an 8-digit Brazilian postal code and will fail on any other data.
This barcode must start with a Start character and end with a Stop character. Characters A, B, C and D can be used as Start and Stop characters.
For the remaining barcode data, the following characters may be used:
This 2D barcode can currently only be used in documents that will be printed using either the Optimized Postscript or Windows Printing mode .
This barcode supports the full ASCII character set based on the 3 alphabets used in the Code128 barcode (see below). The switch between alphabets is done automatically. Special characters in the A alphabet are called with their ASCII value using the following syntax: ^nnn (such as ^010 for LineFeed).
A minimum of 3 characters is required in this barcode. The maximum string length for this barcode varies depending on the control characters used in the code. Bar width is set using millimeters and corresponds to the minimum barcode width.
The following characters are valid for this barcode:
A checksum is optional, but should be added to ensure data reliability. When the Checksum option is selected, the required checksum digits are added automatically.
This 2D barcode can currently only be used in documents that will be printed using either the Optimized Postscript or Windows Printing mode.
This barcode supports the full ASCII character set based on the 3 alphabets used in the Code128 barcode (see below). A maximum of 5 characters per row over 16 rows is permitted. If the first 4 characters in the data are numeric, a 'SwitchC' character is automatically added before the data. Special characters within the data can be used to switch alphabets in the same way as with the Code 128 barcode.
The selected barcode mode determines the starting codeset and leading character:
To go beyond the 44 basic characters listed above, you may use extended ASCII characters (granted that scanners are programmed for this, otherwise extended characters will simply be read as basic characters).
To use extended characters, use the encoding listed in the following table:
Character |
Encode as |
Character |
Encode as |
Character |
Encode as |
Character |
Encode as |
NUL |
%U |
SP |
Space |
%V |
%W |
SOH |
$A |
/A |
A |
A |
a |
+A |
STX |
$B |
/B |
B |
B |
b |
+B |
ETX |
$C |
/C |
C |
C |
c |
+C |
EOT |
$D |
/D |
D |
D |
d |
+D |
ENQ |
$E |
/E |
E |
E |
e |
+E |
ACK |
$F |
/F |
F |
F |
f |
+F |
BEL |
$G |
/G |
G |
G |
g |
+G |
BS |
$H |
/H |
H |
H |
H |
+H |
HT |
$I |
/I |
I |
I |
i |
+I |
LF |
$J |
J |
J |
j |
+J |
VT |
$K |
/K |
K |
K |
k |
+K |
FF |
$L |
/L |
L |
L |
l |
+L |
CR |
$M |
M |
M |
m |
+M |
SO |
$N |
N |
N |
n |
+N |
SI |
$O |
/O |
O |
O |
o |
+O |
DLE |
$P |
0 |
0 |
P |
P |
p |
+P |
DC1 |
$Q |
1 |
1 |
Q |
Q |
q |
+Q |
DC2 |
$R |
2 |
2 |
R |
R |
r |
+R |
DC3 |
$S |
3 |
3 |
S |
S |
s |
+S |
DC4 |
$T |
4 |
4 |
T |
T |
t |
+T |
NAK |
$U |
5 |
5 |
U |
U |
u |
+U |
SYN |
$V |
6 |
6 |
V |
V |
v |
+V |
ETB |
$W |
7 |
7 |
W |
W |
w |
+W |
CAN |
$X |
8 |
8 |
X |
X |
x |
+X |
EM |
$Y |
9 |
9 |
Y |
Y |
y |
+Y |
SUB |
$Z |
/Z |
Z |
Z |
z |
+Z |
ESC |
%A |
%F |
%K |
%P |
FS |
%B |
%G |
%L |
%Q |
GS |
%C |
%H |
%M |
%R |
RS |
%D |
%I |
%N |
%S |
YS |
%E |
%J |
_ |
%O |
DEL |
%T,%X,%Y,%Z |
The data for this barcode can include both numeric and alphanumeric characters. When only numbers are present in the data, the maximum number of characters is 82. When alphanumeric characters are present, the maximum is 50 characters.
To use extended characters, use the encodings listed in the following table:
Character |
Encode as |
Character |
Encode as |
Character |
Encode as |
Character |
Encode as |
NUL |
(%)U |
SP |
Space |
(%)V |
(%)W |
SOH |
($)A |
(/)A |
A |
A |
a |
(+)A |
STX |
($)B |
(/)B |
B |
B |
b |
(+)B |
ETX |
($)C |
(/)C |
C |
C |
c |
(+)C |
EOT |
($)D |
(/)D |
D |
D |
d |
(+)D |
ENQ |
($)E |
(/)E |
E |
E |
e |
(+)E |
ACK |
($)F |
(/)F |
F |
F |
f |
(+)F |
BEL |
($)G |
(/)G |
G |
G |
g |
(+)G |
BS |
($)H |
(/)H |
H |
H |
H |
(+)H |
HT |
($)I |
(/)I |
I |
I |
i |
(+)I |
LF |
($)J |
(/)J |
J |
J |
j |
(+)J |
VT |
($)K |
(/)K |
K |
K |
k |
(+)K |
FF |
($)L |
(/)L |
L |
L |
l |
(+)L |
CR |
($)M |
M |
M |
m |
(+)M |
SO |
($)N |
N |
N |
n |
(+)N |
SI |
($)O |
(/)O |
O |
O |
o |
(+)O |
DLE |
($)P |
0 |
0 |
P |
P |
p |
(+)P |
DC1 |
($)Q |
1 |
1 |
Q |
Q |
q |
(+)Q |
DC2 |
($)R |
2 |
2 |
R |
R |
r |
(+)R |
DC3 |
($)S |
3 |
3 |
S |
S |
s |
(+)S |
DC4 |
($)T |
4 |
4 |
T |
T |
t |
(+)T |
NAK |
($)U |
5 |
5 |
U |
U |
u |
(+)U |
SYN |
($)V |
6 |
6 |
V |
V |
v |
(+)V |
ETB |
($)W |
7 |
7 |
W |
W |
w |
(+)W |
CAN |
($)X |
8 |
8 |
X |
X |
x |
(+)X |
EM |
($)Y |
9 |
9 |
Y |
Y |
y |
(+)Y |
SUB |
($)Z |
(/)Z |
Z |
Z |
z |
(+)Z |
ESC |
(%)A |
(%)F |
(%)K |
(%)P |
FS |
(%)B |
(%)G |
(%)L |
(%)Q |
GS |
(%)C |
(%)H |
(%)M |
(%)R |
RS |
(%)D |
(%)I |
(%)N |
(%)S |
YS |
(%)E |
(%)J |
_ |
(%)O |
DEL |
(%)T, (%)X, (%)Y, (%)Z |
A checksum is mandatory for this barcode (it is always added automatically).
Code 128 uses 3 alphabets, each containing 106 characters:
In the case of alphabet A, to enter the non-printable characters listed as ordinals 64 to 94 in the following table, you must use alphabet B equivalents (for the ACK character, for example, use character f).
The non-printable characters listed as ordinals 95 to 105 can be entered using their ordinal value preceded by ^. To enter FNC1, for example, you would enter ^102. To enter an actual ^ character, you would enter ^062.
Numeric values entered using alphabet C are always considered as digit pairs (0001, for example, for values 0 and 1). Only when you use alphabets A or B can you enter an odd number of digits (001, for example, for values 0, 0 and 1).
Having {} taken as a pair of characters to be converted into alphabet C will fail the job and result in a typecheck error.
The following table lists the characters that can be used in all three alphabets:
Ordinal |
Value in alphabet |
Encoding |
Ordinal |
Value in alphabet |
Encoding |
A |
B |
C |
A |
B |
C |
00 |
SP |
SP |
00 |
11011001100 |
53 |
U |
U |
53 |
11011101110 |
01 |
01 |
11001101100 |
54 |
V |
V |
54 |
11101011000 |
02 |
02 |
11001100110 |
55 |
W |
W |
55 |
11101000110 |
03 |
03 |
10010011000 |
56 |
X |
X |
56 |
11100010110 |
04 |
04 |
10010001100 |
57 |
Y |
Y |
57 |
11101101000 |
05 |
05 |
10001001100 |
58 |
Z |
Z |
58 |
11101100010 |
06 |
06 |
10011001000 |
59 |
59 |
11100011010 |
07 |
07 |
10011000100 |
60 |
60 |
11101111010 |
08 |
08 |
10001100100 |
61 |
61 |
11001000010 |
09 |
09 |
11001001000 |
62 |
62 |
11110001010 |
10 |
10 |
11001000100 |
63 |
_ |
_ |
63 |
10100110000 |
11 |
11 |
11000100100 |
64 |
NUL |
64 |
10100001100 |
12 |
12 |
10110011100 |
65 |
SOH |
a |
65 |
10010110000 |
13 |
13 |
10011011100 |
66 |
STX |
b |
66 |
10010000110 |
14 |
14 |
10011001110 |
67 |
ETX |
c |
67 |
10000101100 |
15 |
15 |
10111001100 |
68 |
EOT |
d |
68 |
10000100110 |
16 |
0 |
0 |
16 |
10011101100 |
69 |
ENQ |
e |
69 |
10110010000 |
17 |
1 |
1 |
17 |
10011100110 |
70 |
ACK |
f |
70 |
10110000100 |
18 |
2 |
2 |
18 |
11001110010 |
71 |
BEL |
g |
71 |
10011010000 |
19 |
3 |
3 |
19 |
11001011100 |
72 |
BS |
h |
72 |
10011000010 |
20 |
4 |
4 |
20 |
11001001110 |
73 |
HT |
I |
73 |
10000110100 |
21 |
5 |
5 |
21 |
11011100100 |
74 |
LF |
j |
74 |
10000110010 |
22 |
6 |
6 |
22 |
11001110100 |
75 |
VT |
k |
75 |
11000010010 |
23 |
7 |
7 |
23 |
11101101110 |
76 |
FF |
l |
76 |
11001010000 |
24 |
8 |
8 |
24 |
11101001100 |
77 |
CR |
m |
77 |
11110111010 |
25 |
9 |
9 |
25 |
11100101100 |
78 |
SO |
n |
78 |
11000010100 |
26 |
26 |
11100100110 |
79 |
SI |
o |
79 |
10001111010 |
27 |
27 |
11101100100 |
80 |
DLE |
p |
80 |
10100111100 |
28 |
28 |
11100110100 |
81 |
DC1 |
q |
81 |
10010111100 |
29 |
29 |
11100110010 |
82 |
DC2 |
r |
82 |
10010011110 |
30 |
30 |
11011011000 |
83 |
DC3 |
s |
83 |
10111100100 |
31 |
31 |
11011000110 |
84 |
DC4 |
t |
84 |
10011110100 |
32 |
32 |
11000110110 |
85 |
NAK |
u |
85 |
10011110010 |
33 |
A |
A |
33 |
10100011000 |
86 |
SYN |
v |
86 |
11110100100 |
34 |
B |
B |
34 |
10001011000 |
87 |
ETB |
w |
87 |
11110010100 |
35 |
C |
C |
35 |
10001000110 |
88 |
CAN |
x |
88 |
11110010010 |
36 |
D |
D |
36 |
10110001000 |
89 |
EM |
y |
89 |
11011011110 |
37 |
E |
E |
37 |
10001101000 |
90 |
SUB |
z |
90 |
11011110110 |
38 |
F |
F |
38 |
10001100010 |
91 |
ESC |
91 |
11110110110 |
39 |
G |
G |
39 |
11010001000 |
92 |
FS |
92 |
10101111000 |
40 |
H |
H |
40 |
11000101000 |
93 |
GS |
93 |
10100011110 |
41 |
I |
I |
41 |
11000100010 |
94 |
RS |
94 |
10001011110 |
42 |
J |
J |
42 |
10110111000 |
95 |
US |
DEL |
95 |
10111101000 |
43 |
K |
K |
43 |
10110001110 |
96 |
FNC3 |
FNC3 |
96 |
10111100010 |
44 |
L |
L |
44 |
10001101110 |
97 |
FNC2 |
FNC2 |
97 |
11110101000 |
45 |
M |
M |
45 |
10111011000 |
98 |
SHIFT |
SHIFT |
98 |
11110100010 |
46 |
N |
N |
46 |
10111000110 |
99 |
Code C |
Code C |
99 |
10111011110 |
47 |
O |
O |
47 |
10001110110 |
100 |
Code B |
FNC4 |
Code B |
10111101110 |
48 |
P |
P |
48 |
11101110110 |
101 |
FNC4 |
Code A |
Code A |
11101011110 |
49 |
Q |
Q |
49 |
11010001110 |
102 |
FNC1 |
FNC1 |
FNC1 |
11110101110 |
50 |
R |
R |
50 |
11000101110 |
103 |
START A |
START A |
START A |
11010000100 |
51 |
S |
S |
51 |
11011101000 |
104 |
START B |
START B |
START B |
11010010000 |
52 |
T |
T |
52 |
11011100010 |
105 |
START C |
START C |
START C |
11010011100 |
STOP |
STOP |
STOP |
11000111010 |
The checksum is always calculated automatically.
This barcode supports the full ASCII character set and its maximum data capacity depends on the data type and the selected barcode mode:
Error correction levels depends on the selected barcode mode. Levels range from 0 to 6 in Rectangular mode, and from 0 to 24 in Square mode. Note that the number of characters available is inversily proportional to the error correction that has been set.
A checksum is automatically calculated. Optional bearer bars can be added for added reliability.
This static code can only represent one of three available FIM types: FIMA, FIMB, and FIMC.
This barcode supports digits only and the maximum number of characters allowed is based on the selected barcode mode.
The Intelligent Mail Barcode is used by USPS to track letters and flats. The barcode has no selectable option, but the data must be formatted in a very specific way to be useable. The data must be one single string of digits, composed of the following items:
For more information on the OneCode barcode, please see http://ribbs.usps.gov/onecodesolution.
A USPS barcode used to track packages. The barcode has no selectable option, but the data must be formatted in a very specific way to be useable.
More information as well as the proper barcode data syntax can be found on the USPS barcode website: https://ribbs.usps.gov/index.cfm?page=intellmailpackage
For more information on the IMPB barcode, please see https://postalpro.usps.com/mailing#cat-subsection-2.
The Japan Post barcode will accept digits and uppercase letters and the hyphen. The data consists of a 7 digit postal code plus address data. If the address data is less than 13 characters the remaining character positions are filled with control characters to make the length 20.
The postal code section may have a hyphen at the 4th character position (eg. 123-4567) although this hyphen does not appear in the encoded data. There may also be a hyphen between the postal code and the address data (eg. 154-0023-1-3-2-A-507). Again this hyphen does not appear in the encoded data. Note that the remaining hyphens are encoded.
The barcode has no selectable option, and the following characters are valid for this barcode:
This 2D barcode can be used in documents that will be printed using the Optimized Postscript, Windows Printing or printer centric mode.
This barcode supports various data types and the maximum number of characters allowed is based on the selected barcode mode:
Note that the Barcode Options page of the Barcode dialog box may also be used to enter the data. When
mode 2 or 3 is selected, all the corresponding dialog box fields are accessible. When mode 4, 5 or 6 is
selected, only the Message dialog box field may be used to enter data. Entering data this way supersedes
any data entered using the Data page of the Barcode dialog box.
The number of columns in the barcode may be selected as required up to a maximum limit of 4 columns.
Note that the error correction level is always set automatically.
Error correction may be set from Level 0 to Level 3.
This code can contain a variable number of characters. The following characters are valid for this barcode:
A checksum is added automatically.
This 2D barcode replaces the PDF417 barcode used in previous versions of PlanetPress Design. It can be used in documents that will be printed using the Optimized Postscript, Windows Printing or printer centric mode.
If you open document that uses the “old PDF417 barcode”, existing PDF417 barcodes will remain unchanged, and any new PDF417 barcode that you may add to that document will also use the “old PDF417 barcode”. If you want this older document to use the new barcode, you will have to delete all its “old PDF417 barcodes”, to save the document, and then to add new PDF417 barcodes. Barcodes added to older documents that did not contain any PDF417 barcode or to new documents will be added using the “new PDF417 barcode”.
The number of columns in the barcode may be selected as required up to a maximum limit of 20 columns.
Error correction may be set from Level 0 to Level 8.
Place a checkmark in the Truncated box to make the barcode a truncated PDF417 barcode. By default, barcodes are added as standard PDF417 barcodes.
A two-digit checksum is added automatically.
Standard Postnet codes must contain exactly 5 characters. The following characters are valid for this barcode:
Apart from the standard Postnet code, two additional codes can also be used:
A variant of the Datamatrix Barcode, the Royal Mail Mailmark barcode has a different internal encoding and limited barcode sizes as compared to the original Datamatrix. This barcode supports the full ASCII character set and its content should respect the Mailmark specifications by Royal Mail.
Error correction levels depends on the selected barcode mode. Levels range from 1 to 2 in Square mode, and is fixed to level 1 in rectangular mode.
The UPC barcode in PlanetPress Design supports multiple subtypes:
UPC-A
Standard UPC-A codes must contain exactly 12 characters (including the checksum character). The following characters are valid for this barcode:
Apart from the standard UPC-A code, two additional codes can also be used:
UPC-E
Standard UPC-E codes must contain exactly 8 characters:
Apart from the standard UPC-E code, two additional codes can also be used:
EAN-13
The standard code must contain exactly 13 characters (this includes one checksum character).
Apart from the standard EAN-13 code, two additional codes can also be used:
A checksum is automatically calculated for this barcode.
Human readable characters are always included in the code.
EAN-8
The standard EAN-8 code must contain exactly 8 characters (this includes one checksum character).
Apart from the standard EAN-8 code, two additional codes can also be used:
ISBN
Standard ISBN barcodes contain 10 digits (9 digits for the data plus 1 checksum digit) or 13 digits (a 3 digit prefix, 9 digits for the data plus 1 checksum digit).
Using hyphens or spaces is not compulsory but recommended to clearly separate each part of the code.
Apart from the standard ISBN code, two additional codes can also be used:
