Use: |
To: |
SHIFT+UP ARROW, SHIFT+DOWN ARROW (when at least one element is selected) |
Add the next element above or below the currently selected elements, to the selection. Recall that you can only add elements to the selection that are at the same level in the hierarchy. |
CTRL+A |
Select all elements at the same level in the hierarchy. |
F2 (after selecting an element) |
Rename the element. |
