Returns the remainder resulting from the division of two numbers.
mod( number1, number2 ) integer value
number1 mod number2 integer value
number1
Integer value to be divided.
number2
Integer value with which to divide number1.
This example uses MOD to distinguish between odd and even numbers.
define(&i,integer, 1)
%Define loop variable
for(&i,1,1,10) %Set loop
show(inttostr(&i)+' is an') %Display number
if(mod(&i,2)=1)
%Determine if number is odd or even
show(' odd ')
elseif()
show(' even ')
endif()
show('number.')
crlf()
endfor()
