8.18/6/2018
Custom Data Selections
To create a Custom data selection:
  1. Open the properties dialog box for the object for which you want to create a data selection.
  2. In the properties dialog box, click Data.
  3. Select Custom data selection.
Create the Custom data selection using PlanetPress Talk. You can enter the selection on a single line, or divide it over several lines, depending on the selection you are trying to create and how you define it. If you create a complex data selection, breaking it up over several lines can make it more readable. When you break a selection over several lines, for each line, you determine whether to terminate it with a carriage return followed by a line feed (CRLF).
Both the String to display lines and the CRLF lines accept PlanetPress Talk expressions.
Navigating, inserting, deleting and repositioning lines:
Once you are done with your custom data selection, Click OK to close the object properties and save your changes.
If necessary, step through the sample data file to verify the data selection is accurate for the record sets in the sample data file.
