OMR Mark Object
The OMR Mark Object displays optical marks on each page of a document when it is output to a printer. These marks are read by the folder-inserter to produce the appropriate output from the machine. This object is only available when a settings file has been selected in the Document Properties.
In addition to the common object properties, shape objects have the following properties:
- Parameters: Displays a list of available settings for the OMR Mark. Generally, not every mark in the OMR will be configurable here, as some are automatically added and removed.
- Settings: Displays the name of the setting. Read-only value.
- Value: Enter a boolean value or PlanetPress Talk Expression that will determine if the setting will be true or false for this page.
