A step-by-step animation of this section is available online by clicking here.
| Navigating the preview | ||||||||||||
Starting at this point a preview of your project's output appears. You can navigate through the preview window using the navigation icons or keyboard shortcuts. Panning and zooming
Changing PagesTo move forward click on the Next button. To move back click on the Back button. To move to the first page click on the the First button, to move to the last page click on the Last button. To hide the navigation window, click the Hide button.
Boundaries are the divisions between each of your mail piece (one mail piece being the contents of an envelope). When one mail piece ends and a new one starts, that is a boundary. Boundaries can be defined using a set of different rules depending on the type of job you are doing.
Select this option if you have a variable number of pages for each mail piece. You will need to know if the information necessary to determine when a mail piece starts or ends is on the first or the last page. Both of the options, The first page and The last page, can be used depending on the location of the information.
Select this option if your mail pieces always contain a fixed number of pages throughout your job. When selecting this option, the The rule will look for... selector disappears and an input box appears in its place. Enter the exact number of pages each document contains.
Select this option if your mail pieces are separated by a specific paper type, for example by a blue cover sheet that is pulled from a different paper tray in the printer. When selecting this option, a drop-down appears with the supported media types. Click on the option that corresponds to the media type change you want to detect.
For all the selections except Orientation Change, an input box appears next to your selection, and should list the media types that are attached to the job. Enter the desired trigger or select one from the list. The exact wording here depends on the media calls in your printer driver. Please refer to your printer's documentation for more details on what options are available to you.
Some input methods may not support all media type selections. PDFs in particular may be affected by this limitation.
Select this option if your boundaries are defined depending on text on your page and whether this text has changed or is something specific. Then, create a region of text on the page by clicking and holding the mouse button in one corner of the region you want to create, then moving to the opposite corner and releasing the mouse button.
It is much more effective to select a single line of text if you can. This can make your process slightly faster if using a lot of conditions on a large job.
The Selected Region Condition box appears once you have created a region selection.
Select one of the options from the following:
Depending on the option you selected it may be necessary or appropriate to modify the content of the text box next to the selection since by default it contains the text within the region selection.
The contents of the region may change in height (for example because of an optional second address line) or width (larger names or addresses), so plan ahead and take a larger area if necessary. As long as no other text is included in your selection, the empty blank spaces are trimmed automatically.
To create a new condition, click the
button. Define a new region selection in your preview for this new condition. Select the condition type and modify the content of the text box, if appropriate.
The changes condition should only be used as the last condition in the set. If it is not the last, it may not function correctly.
To delete a condition, go to the condition you want to delete and click the
button. The condition will be removed.
To navigate between conditions, click the
and
buttons. The label between the buttons indicates the number of conditions and the currently visible one (for example, 1/2).
You can combine the conditions in two ways:
