Installing PlanetPress EnvelopeNOW
To install PlanetPress EnvelopeNOW follow these steps:
In order to install PlanetPress EnvelopeNOW, you must be logged on as an administrator on the computer.
- Navigate to the PlanetPress EnvelopeNOW.exe file you downloaded from the Internet or locate the file on the PlanetPress EnvelopeNOW product CD. Once located double-click its icon to launch the installation program. The Select Setup Language dialog appears.
- Select your preferred language and click OK.
Version 1.0 of PlanetPress EnvelopeNOW is only available in English.
If your computer is missing prerequisites necessary for PlanetPress EnvelopeNOW to be installed, a dialog appears and indicates that they will be installed.
- Click Next to download and install the required components. Once the installation of the components is completed the Welcome screen is displayed.
- Click Next. The License Agreement page is shown.
- When you have read and understood the license agreement, click on I accept the terms of the license agreement. Click Next.
You must accept the terms of the license agreement to continue.
- Enter your full name and your organization's name then click Next.
- The Setup Type screen appears. Select Complete if you want to install all the components of the software, or Custom if you want to individually select the components to install. Click Next.
- If you selected Custom, the Custom Setup window appears. Select the components you want to install then click Next.
- The Destination Folder screen displays the drive and folder where PlanetPress EnvelopeNOW will be installed. To install the software elsewhere, click Change... and navigate to the desired folder.
- The Program Folder name determines the name that appears in the Start Menu. Keep the default name or change the name as desired. Choose whether you want the shortcuts to appear for anyone that uses the computer, or only for the currently logged on user, then click Next.
- Click Next to start copying the files and install the software. The Setup Wizard starts installing the files.
When the copying is complete, the final window appears.
You may check Run Update Client now to check for updates after the installation has finished (recommended).
- Click Finish to complete the installation of PlanetPress EnvelopeNOW.
Updating PlanetPress EnvelopeNOW
We strongly recommend keeping your software up to date by regularly using the Objectif Lune Update Manager.
To access the PlanetPress EnvelopeNOW update manager, do the following:
- Click Start.
- Click (All) Programs.
- Click the Objectif Lune Update Client icon.
When you start the update manager for the first time, a warning window appears to confirm whether you want information about your system to be sent to Objectif Lune. This information is only related to the Objectif Lune products installed on your system. Click Yes to accept, No to cancel. If you click Cancel, the update manager will quit and your software will not be updated.
To install an update:
If a new update exists for any Objectif Lune software installed on your system, including PlanetPress EnvelopeNOW, the latest version will appear along with its download size and an Install button. Click on the Install button to start the download and installation of the latest software version.
Once the download exits, the installation will start. Follow the instructions in this guide if you need help with the installation of the update (see Installing PlanetPress EnvelopeNOW)
