7.5
2014-03-28
Set User Options
You can set a number of user options in PlanetPress Search. With the exception of two user options, Use default profile (in Program startup options) and Database access for new profiles (in Search options), all user options apply to the currently loaded search profile and are saved with it. Each time you load a search profile, the user options settings adjust to reflect those of the newly loaded profile.
Note that if the file containing the search profile is read-only, you cannot save any of the modifications you make to the user options settings. In this case, any changes you make to the user options settings are available only until you load a different profile or exit PlanetPress Search. It is common to make search profiles read-only in a network installation. See Database Considerations in a Network Installation.
Here are the user options available in this dialog:
Program startup options tab
Printing options tab
Search options tab
Database options tab
This tab sets the options for creating, rebuilding, and refreshing the database associated with this search profile. Note that if the search profile has its ReadOnly entry set to 1 (as for example in a network installation), these options are not available in the User Options dialog box.
To restore default user options settings:
From the User Options didalog, click on Reset All. This will reset the user options for the currently loaded search profile.
