This procedure describes how to select one or more search results in the Results area.
To select one or more search results:
If you performed a search on all documents in the database, expand the document in the Results area that you want to select search results from.
PlanetPress Search displays the results below the document in the Results list.
In the Results list, click a search result.
PlanetPress Search highlights that search result.
You can add search results to the selection by doing either of the following:
CTRL+click a search result to add it to the selection. CTRL+click the same search result a second time to remove it from the selection.
SHIFT+click a search result to add it and all the search results that appear between it and the previously selected search result.
PlanetPress Search highlights each search result you add.
For example:
