7.5
2014-03-28
Implement a Trigger and Configure an AIX 4.3 Printer
Add a Physical or Virtual Printer
To add a physical or virtual printer in series:
  1. Log in as dyadm.
  2. Execute SmitPrinter.
  3. Select Print Spooling.
  4. Select Add a Print Queue.
  5. Select Local.
  6. Select Other, regardless of the type of printer.
  7. Select Generic, regardless of the type of printer.
  8. Select parallel or rs232.
  9. Select the appropriate adapter(s).
  10. Enter the following values:
    ASCII: Name of virtual printer that prints from operating systems.
    GL Emulation: Laser printer configured on a workstation and used for Windows printing.
    Port number: Number of ports on the serial communication card.
    Baud rate: Port speed.
    Parity: Parity type.
    Flow control: Printer's protocol type.
    Printer time out: Time a printer can time-out before being DOWN.
    State to be configured at boot time: Always be at AVAILABLE.
To add a physical or virtual printer connected to a Jet Direct:
  1. In the /etc/hosts file, enter the IP address and print server name.
  2. Follow step 1 through step 5 in To add a physical or virtual printer in series:. In step 5 select hpJetDirect.
  3. Select Other, regardless of the type of printer.
  4. Select Generic, regardless of the type of printer.
  5. Select Do NOT make this system a BOOT/TFTP server.
  6. Enter the following values:
    ASCII: Name of printer for AIX, Basic and Informix printing.
    HOSTNAME: Name entered in the /etc/hosts file.
    Port number: For JetDirect: 9100. For a three-port: Port 1 = 9100, Port 2 = 9101, Port 3 = 9102.
To add a physical or virtual printer configured on another server:
  3. Select Remote.
  4. Select Local Filtering.
  5. Select Other.
  6. Select Generic.
  7. Enter the following values:
    GL emulation: Laser printer configured on a workstation and used for Windows printing.
    Queue name: Name of the printing queue on the other server.
    Backend time-out: Length of time, in seconds, the AIX server waits for information from the printer before disconnecting the printer. The recommended value is 30.
To add a new print queue on an existing device:
  1. Follow step 1 through step 8 in To add a physical or virtual printer in series:.
  2. Select one of the following options:
    Add new printer: To create a new printer, select Add new printer. Return to step 8 in To add a physical or virtual printer in series:.
    Existing printer: To edit a new queue on the lp printer/device, select the appropriate printer.
  3. Enter the name of the new printer.
To modify the attributes of virtual printers:
  1. Log in as dyaddm.
  2. Execute Smit Printer.
  3. Select Programming Tools.
  4. Select Change / /Show Printer Attribute Database (Virtual Printers).
  5. Select the virtual printer to modify.
  6. Change the following attributes for the ASCII printers only:
    J: !
    Z: !
    _j: !
    _l: 0
    _w: 255
    cr: %Iac
