Job fileWhichever source it may come from, a serial port, an e-mail message, or an LPR request, for instance, and whatever its format, data entering a PlanetPress Workflow process via an Input task is always referred to as a data file. When a data file enters a process, it becomes the job file. A single job file can be the source of multiple job files. This is the case, for example, when a process includes multiple branches, as each branch is given a duplicate copy of the job file (see About branches and conditions). This is also the case when a job file is split into multiple smaller files by a Splitter Action task, for instance (see Data Splitters). It is important to note that job files may be used as a helpful debugging resource (see Debugging and error handling). Job file names are generated automatically and stored in the %f system variable (see Job file names and output file names). Actual data and sample dataThe actual data is the dynamic data captured by PlanetPress Workflow at run-time. The sample data file is a static sampling of the run-time data (see Sample Data). |
