Line printer emulationLine printer emulation tells the process to treat the input data as data destined for a line printer. In this emulation, a form feed signals the end of a data page. If no form feed occurs in the data stream, the emulation adds lines to the data page buffer until the buffer is full. Line printer emulation offers the best overall performance of all the emulations. Line printer emulation is only used when merging line printer data with a PlanetPress Design document.
When choosing a line printer sample data file to be merged with a Connect template, select Text emulation (see Text-based emulation). Line printer emulation optionsThe line printer emulation does not have any options other than the general text-based emulation options (see Text-based emulation). |
