XML EmulationXML data emulations allow you to capture data emanating from web databases, e-mail fulfillment, e-commerce, and general XML database engines. In XML emulation, the data elements in markup language format are organized in a folder view with a root node and sub-level nodes. Characters referenced using the ϧ syntax are limited to values ranging from 000 (�) to 256 (Ā).
When XML data is merged with PlanetPress Design documents on a printer DOCTYPE and ENTITY tags are ignored.
XML emulation options
For information about XML emulation options in PlanetPress Design documents, see the PlanetPress Design user guide. |
