Adding Branches
The PlanetPress Workflow Configuration program offers two different methods when it comes to adding new branches to a process.
- You can add a new branch by dragging and dropping a Branch from the Process Logic category of the Plug-in Bar into your process. Branches can thus be added like a task; see Adding tasks.
- Alternatively, you can add a new branch that contains all of the tasks below the point where you insert the branch. To do this, right-click on the first task that you want to include in the branch, and select Branch From Here.... An unknown task will be created as an output below the branch.
