Configuration Components Pane appearance preferences
Colors
This window lets you set the color of individual Configuration Components pane elements. To change the color of a given element, select it in the list box above and then choose a color from the drop-down list below.
Options
  • Line Style: Select the style (dotted or solid) of the line that connects the different objects in the Configuration Components pane.
  • Selection rectangle: Select whether your selection rectangle (used to select multiple objects by dragging a rectangle around multiple objects) will be displayed as a dotted line rectangle, or a blended rectangle (normally a blue rectangle with darker blue border).
  • Button Style: Select whether to show the expansion links as either an arrow (points right for a closed tree, down for an open tree) or a square (shows a minus symbol for an open tree, plus symbol for a closed tree).
  • Show Tree Lines: Check to choose whether or not to display the lines that connect the different objects in the Configuration Components pane.
  • Show Grid Lines: Check to choose whether or not to display grid lines between each object in the Configuration Components pane.
  • Hot track: Check to choose whether or not to display the object in the Configuration Components pane under the mouse cursor as being underlined.
  • Reset To Defaults button: Click to reset all the Configuration Components pane appearance options to their default values.
  • Last Topic Update: Aug-21-2018 - 10:08
