General and logging preferences
General plugin preferences control the level of detail added to the PlanetPress Workflow log file. Since log files cover 24 hours of operation, choosing to log every task performed by PlanetPress Workflow may result in the creation of excessively large files.
Changing the plugin preferences also affects the logs displayed in the PlanetPress Workflow Service Console.
  • Log level group
    • Startup and shutdown: Select to only track when the PlanetPress Workflow service is started and stopped.
    • Task failure: Select to only track when tasks in the processes running in a PlanetPress Workflow configuration fail.
    • Task success and failure with details: Select to track when the tasks in processes running in PlanetPress Workflow succeed and fail, with details. Details can include why tasks fail and how successful tasks are executed.
    • All events with details: Select to log everything that happens in PlanetPress Workflow. This includes when it starts and stops, the success and failure of tasks, and details on the success and failure of tasks.
  • Add time stamp to all processes events: Adds a time stamp to each log entry for a process event.
  • Delete log files after: Select how many days log files are kept before being deleted.
  • Maximum numbers of replicated processes: Set the maximum number of times a process may be replicated.
  • Last Topic Update: Aug-21-2018 - 10:08
