The Plug-in BarPlanetPress Workflow offers a constantly increasing number of plugins, while always allowing third party plugins to be installed and set up to be used by PlanetPress Workflow. The PlanetPress Workflow Plug-in Bar lists all plugins available in PlanetPress Workflow, and is divided into categories, which users can customize at will. Most of the PlanetPress plugins are installed by default, but other plugins may be added. Because the plugins are always expected to execute some sort of task, they are always referred to, in this documentation, as tasks, except in the specific case of importing a new plugin or customizing the Plug-in Bar. See also: About Tasks. Categories
The default categories list plugins according to what type of task they achieve. When first starting your PlanetPress Workflow program, the following categories are used:
An Uncategorized category is dynamically created if your PlanetPress Workflow finds any plugin that would not be part of the existing Plug-in Bar. User-defined plugins and third party application plugins fall into such a category. Settings & customizationThe Plug-in Bar can be customized according to your needs and the plugins you most frequently used. You can use the horizontal dark blue bar separating the plugin area and the list of categories to change how many plugin categories are displayed as the full-width bar with the title, and how much are displayed as icon only. Move the bar up to display more full-width categories, or down to display them more as icons. Furthermore, the Plug-in Bar can be customized using the popup indicator control ( Using the contextual menu displayed by the popup indicator, you can:
Importing a plugin
New plugins appear in the Uncategorized category. |
