Removing tasks or branchesTo remove any task or branch (except Input and Output tasks), use one of the following methods:
When you remove a branch, all the tasks located in that branch are also deleted. When you delete a task, only that task is deleted. You cannot use the Delete option to remove an input or output task, but you can right-click on them and click Cut instead. This replaces the task with an Unknown task (see Unknown tasks). To delete the path below a branch crossing (instead of the path to the right of the branch):
