The PlanetPress Workflow Service ConsoleThe PlanetPress Workflow Service Console is a centralized service console and log viewer in one. You can use it to individually start and stop PlanetPress Workflow services, as well as to view current and past log files for each service. The Service Console has changed greatly since version 7.4. If you are still using an older version of PlanetPress, please see the user manual for your version instead. Controlling ServicesThe left part of the PlanetPress Workflow Service Console displays a list of the PlanetPress Workflow services and is used to control these services. To start a stopped service:
To stop a service that is running:
To pause a service temporarily:
To kill (force quit) a service:
Viewing log filesThe second major role of the Service Console is to view and browse log files. The Service Console can both view existing log files, or monitor the log file for the current day and update the view in real time. When a service is selected on the left pane, its log file (if any exists for the current day) is displayed. The log displays in a tree fashion. The log itself is the root, and each session (the time between the start and stop of a service) is listed. Under each session, each time a process runs, a new branch is created and it can be expanded to see each action within that process. The log viewer for the current day is always live, meaning it updates automatically as the log file is updated by the appropriate service. Viewing older log filesTo open an existing, older log file:
The log viewer for existing log files does not refresh automatically since log files for older days do not generally change. The display of the sessions, processes and tasks is the same. The log viewer as described here was introduced in version 7.4 of PlanetPress Workflow. Though it should be able to open log files from older versions of PlanetPress Workflow, the results are not guaranteed. Some log files may not display properly in this view. Searching through the active log fileWhen a log file is active in the log viewer, it can be searched by going in the Search menu, then clicking Find. After entering a search term and selecting the options (Match case and Direction), clicking Find Next will display the first result for the search term. When a search is started, using F3 on the keyboard or clicking Search then Search again will find and highlight the next available result. |
