LaserFiche Repository Output Task - Configure Tags
Tags are an optional method for categorizing documents that can be added to, or removed from a document at any point.
Configuring tags
- Selecting a tag will assign it to the exported documents.
- There are two types of tags: informational tags (icon with an exclamation mark ("!")), and security tags (icon with a lock).
- All tag properties are the same as in the Laserfiche client console.
- The Comments columns allow the addition of comments to the tag. This column supports the use of any PlanetPress Workflow variables.
Restrictions
- The Comments column in the Configure Tags interface allows a maximum of 200 characters.
- If you want to assign an Informational tag, do not select the Security tag option in Laserfiche admin console.
