Create FileCreate File input tasks are different from other input tasks in that they do not pull in data from a source location. The data that this task passes along to other task is its own: text or values from variables entered when the task was created or last edited. Since Create File input tasks are not dependent on data from external sources, they are performed at every polling interval and the process is thus started every time. This task is put into effect in the following use cases and example processes: InputCreate File does not capture any file and, if it is a secondary input task, discards the current data file. ProcessingCreate File generates a job file with the contents of it's text. If variables and control characters are present, they are evaluated at run-time when the task is executed. OutputThe output is the job file. No metadata is generated by the task itself, however if metadata is present in the job and it is not deleted (in the "Other" tab), it will remain active. Task propertiesGeneral Tab
"Other" Tab
Job Information definitionsThis task does not generate any job information. On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
