File Size Condition
File Size conditions test the size of the job file they receive. Note that the job file may include data selections, attachments and documents that were added by other tasks. If a file does not exist, it's file size will be 0kb.
This task is put into effect in the following example process:
  • File size is: Select whether the condition is to check if the job file is smaller (less than) or larger (more than) then the specified value.
  • Kbytes: Enter the minimum (more than) or maximum (less than) size setting in kilobytes.
  • Invert condition result: Select to toggle the result of the condition (true becomes false and vice versa).
Comments Tab
The Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane.
  • Last Topic Update: Aug-20-2018 - 10:08
