Folder Listing
Folder Listing input tasks list the files present in a selected folder and gives you the option to use filename masks, to sort files by name or date, and to list the files present in the selected folder’s subfolders. The lists it generates are in XML format.
Folder Listing captures nothing, however it does read the input folders (and, if selected, subfolders) and gathers information about each file in that folder.
Folder Listing loops through the files and, for each file, generates an XML node with information about the file.
The output is an XML file containing information about each file. If the Sub-directories option was checked, the structure of the XML also contains the folder structure as it is present on the drive.
Here is a sample of the XML that is generated:
<?xml version="1.0" encoding="windows-1252"?>
<files count="3" filemask="*.*">
    <folder>C:\Samples\<file>
            <filename>invoice.pdf</filename>
            <path>C:\Samples\</path>
            <time>2012/06/01 16:14:40</time>
            <size>81452</size>
        </file>
        <file>
            <filename>test1.pdf</filename>
            <time>2013/01/17 09:13:50</time>
            <size>20197</size>
        </file>
    </folder>
    <folder>C:\Samples\manuals\<file>
            <filename>usermanual.pdf</filename>
            <path>C:\Samples\manuals\</path>
            <time>1999/10/06 09:52:04</time>
            <size>644037</size>
        </file>
    </folder>
</files>
The <time> tag is independent of the OS locale, language or settings. The format is always YYYY/MM/DD 23:59:59.
  • Input folder: Enter the path of the folder that contains the files you want listed.
  • Sorted by: Select either Name or Modified date, depending on how you want the list top be sorted.
  • File mask: Edit the default file name mask (*.*) if you want only some of the files present in the folder to appear in the list. See Masks.
  • List files in sub-directories also: Select this option if you want the task to list any files present in subfolders of the selected input folder.
"Other" Tab
  • Job Information group
    • Information elements: indicates what job infos are automatically created by the input task.
    • Add lines before first data page: Using the arrows keys you can add any job information directly at the beginning of your data file.
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PlanetPress Suite Workflow Tools working folders under the "Backup" folder.
  • Backup filename: Enter the filename that you wish the input data file backup to be saved under.
  • Delete Existing Metadata: Check to remove any metadata from memory. This option is disabled on initial input tasks, and is checked by default on secondary input tasks.
Job Information definitions
  • %1- Folder: Contains the full path of the base folder from which the files are listed.
Comments Tab
The Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane.
  • Last Topic Update: Aug-20-2018 - 10:08
