Go SubThe GoSub action task transfers the execution of the calling process to the specified subprocess (see About processes and subprocesses). When a process encounters a GoSub action, it halts its own execution, start the subprocess and waits for it to complete before resuming its workflow with the next task. Every subprocess starts with a BeginSub input task and ends with a EndSub output task, both of which have nothing to configure and cannot be replaced or deleted. The simply represents entry and exit points for the subprocess. While it is possible to place a GoSub action within a subprocess, doing so will hide the subprocess from any GoSub action, in order to avoid circular referencing (aka an infinite loop). Task propertiesGeneral Tab
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
