LPD InputLPD (Line Printer Daemon) Input tasks retrieve data in the form of print files sent from remote computers using the LPD/LPR protocol. The PlanetPress Workflow LPD server starts automatically when a configuration that includes at least one active LPD Input task is started. To prevent conflicts between competing LPD servers, you must not run any other LPD server than the PlanetPress Workflow LPD server on PlanetPress Workflow workstation. LPD Input tasks are configured primarily through user options (see LPD Input plugin preferences). The only LDP information you enter in each LPD task is the queue name. InputThis task does not poll an input, it sits there and waits for a job file to be sent through the LPR port. ProcessingWhen the job is received through LPR, it is saved as a job file. No further processing is done on the file. OutputThe task outputs the job file as is, with no evaluation or modification. Task propertiesGeneral Tab
"Other" Tab
Job Information definitions
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
