Lookup in Microsoft® Excel® DocumentsThe Lookup in Microsoft® Excel® Documents action task is used to complement your job file's Metadata by retrieving data from a Microsoft® Excel® spreadsheet on your system. The data retrieved is based on existing data in your Metadata, and it will either be added to your Metadata or will append or replace your existing Metadata if it exists. Fields on any level (Page, Datapage, Document, Group, Job) can be used, and the result field will be added on the same level as the lookup field. This task will automatically "loop" through the Metadata and repeat its action for each of your Metadata's data pages. This task should not be placed after a Metadata Sequencer task, otherwise it will run as many times as there are Metadata sequences, which will result in decreased performance. Use casesHere are some examples of how the Lookup in Microsoft® Excel® Documents task could be used in combination with PlanetPress Design documents. Use case 1: Send personalized emails with promotional document attachedA PlanetPress Design document takes a PDF file as the input data file, and reproduces it exactly as it enters. The document also contains a custom data selection set to hold an email address. The data selection's value is given by a Metadata Field called 'Email'. The value of this Email Metadata field is a region from the sample data file representing the customer number. At production time, the Lookup in Microsoft® Excel® Documents action task will replace the value of this Metadata field with the corresponding customer email. Use Case 2: Translate a list of line items descriptions into a given languageA PlanetPress Design document takes as input a transactional PDF file, and reproduces it exactly as it enters. Metadata fields called ItemDesc are created, one for each line item description, at the data page level. Each ItemDesc Metadata field is given the value of a line item description as found on a region of the current data page. The line item descriptions appearing on the resulting page produced by the design tool are custom data selections whose value come from the corresponding ItemDesc Metadata fields. The Lookup in Microsoft® Excel® Documents action task updates the value of all 'ItemDesc' Metadata fields with their corresponding foreign language descriptions. InputAny compatible data file. This task requires Metadata to be present. ProcessingThe task parses each level of the Metadata and, for each field of the specified name it finds, a lookup is made. If a field of the same name appears on multiple levels, the lookup will happen for all fields, on all levels, individually. OutputThe original data file is unchanged. Metadata is updated according to the specified criteria. Task propertiesGeneral Tab
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
